How to test catalog in service portal and catalog task state should be closed using ATF
Raghav22
I have created catalog item and also workflow is attached to create catalog task but after that i want to closed catlaog task state to closed complete and also validate RITM is also complete or not.
Below are the steps which i created. I do now it will not produce me to expected result please help me for getting result.
@Ankur Bawiskar appreciated if you help me.
Raghav
21 REPLIES 21
Step 7 should be Request = Step 5 Output
Muralidharan BS
There are some oob atf tests which you also use for reference,
1. Submit Create Incident Record Producer (SP)
2. Search and Open Catalog Item (SP)
Hi Murali,
I went through oob but i didn't get much help. Could you please suggest me with steps?
Raghav
SumanthDosapati
When you have workflow to generate catalog task, you should not use ATF to create a new catalog task again.
Fine.. then i will remove catalog task step but can you please add me what steps should be added or is there any need to repair .
