How to test catalog in service portal and catalog task state should be closed using ATF
Raghav22
I have created catalog item and also workflow is attached to create catalog task but after that i want to closed catlaog task state to closed complete and also validate RITM is also complete or not.
Below are the steps which i created. I do now it will not produce me to expected result please help me for getting result.
@Ankur Bawiskar appreciated if you help me.
Raghav
21 REPLIES 21
Table is 'sc_task'z
Condition :
Request item is Step7.Record_id
Hi Sumanth,
I tried using your suggestion, please correct me i am having bit confusion.
For Step 4 open a from - which table should be selected?
For Step 7 Run server side script - which script should be mention?
For Step 12 Record update - i have selected state as complete but which table it should and what record should be mention?
For Step 13 Open an Existing record - what record should be selected?
Which table should i select for Step 8,9,10,11,12,13?
Please helpme out with this questions.
Raghav
