How to trigger notification through flow designer
03-23-2022 04:43 AM
How to trigger notification through flow designer. i am not able to get notification records into "send notification " in flow designer.what is the process to trigger notification through flow designer.
03-23-2022 05:24 AM
Refer this - https://developer.servicenow.com/dev.do#!/learn/courses/rome/app_store_learnv2_flowdesigner_rome_flow_designer/app_store_learnv2_flowdesigner_rome_notifications_in_flow_designer/app_store_learnv2_flowdesigner_rome_exercise_send_a_notification
07-07-2022 01:53 PM
Set the 'Send when' field on the notification you are wanting to trigger from within a flow to 'Triggered'.
07-07-2022 05:32 PM
Hi Madhu,
Please follow below steps-
1) Go to actual notification(which do you want to send).
2) When to send tab and set send when to triggered
3) Go to flow designer, select send notification and you you will see name of the notification.
Please mark helpful/correct
Neha
