How to update parent record using business rule
Sai25
I have created a after business rule. When change is created need to update the change record in the under parent field in release table.
below is the script.
var gr=new GlideRecord('rm_release');
gr.addQuery('change_request',current.sys_id);
if(gr.next()){
gr.parent=current.sys_id;
gr.update();
Thank You,
Sai.
12 REPLIES 12
what is your exact requirement ? do you have change request available on rm_release table record ?
script would be like
gr.addQuery('parent',current.sys_id);
gs.log(' Row count is '+ gr.getRowCount());
Hi Harsha,
When record is inserted in change table parent  should be populated with release record and in release table parent should be populated with change record.
Hi Harsha,
Row count is 0
