How to use toggle script. I need to set automatic onhold in SCTASK in 30days
Jeck Manalo
I am trying to create script to automatic set the onhold into 30days how can it be possible on the workflow using toggle script ?
Hello Jeckson,
So you should be able to set this field as per the script provided above. If you field is of Date type then you can use the below script:
var nd= new GlideDateTime(gs.nowDate());
var fd = new GlideDateTime(nd);
fd.addDays(30);
var dueDate = fd.getDate();
return dueDate;
This is what I have used and the due date is getting set on RITM table. do you want to set the on hold date 30 days later based on some other field value?
Please mark my respsone as helpful/correct, if it answer your question.
Mahendra RC
Hello Jeckson,
Please check once if the below script helps you:
fd.addDays(30);
return fd;
Hi Mahendra,
I need to put the date in this variable "On hold Date" using the toggle scripting
How can it possible to do that ?
Hello Jeckson,
fd.addDays(30);
return dueDate;
Thank you for this. it works
