How to use window.location.href.contains() in script include?
Thousif S N2
I need to push field as mandatory based on the ui view . So i want to make the validation based on URL using  window.location.href.contains(). So if the url belongs to second UI page then make field as mandatory? But i am trying its not working ! so can any expert help
Thanks in advance
@Thousif S N
Would you mind marking my response as correct & helpful if I am able to resolve your query?
26 REPLIES 26
From where your script include is getting called?
from UI action
If these are standard change templates, fields are getting mandatory from client script 'Check Template Values'. Its onsubmit client script. Find a part of script which is making mandatory.
function isMandatoryFieldsSet(q) {
var unfilledValues = ' ';
var mandatory = sncStdChg.mandatory;
/*From Here add your customization.
if(location.href.toString.indexOf('value')>=0)
mandatory.push('Your field');
if (mandatory) {
for (var i = 0; i < mandatory.length; i++) {
var m = mandatory[i];
if (q) {
var idx = q.names.indexOf(m.name);
if (idx === -1 || q.vals[idx] === '')
unfilledValues = unfilledValues + m.label + ', ';
No need to make changes to the script include.
Hi maheshn,
It doesnt seems to be working as it is custom table.
can you tell how to check url in script include?
Are you determining fields to be set as mandatory from the script include?
Can you explain the process what you are doing?
top.location won't work in script include code
