How to use window.location.href.contains() in script include?
Thousif S N2
I need to push field as mandatory based on the ui view . So i want to make the validation based on URL using  window.location.href.contains(). So if the url belongs to second UI page then make field as mandatory? But i am trying its not working ! so can any expert help
Thanks in advance
@Thousif S N
Would you mind marking my response as correct & helpful if I am able to resolve your query?
26 REPLIES 26
hi,
Requirement :
We have a 'Standard change Proposal',so when we creating a new template where we have a configuration item field as Mandatory so once the user saves(not submiting) the form after saving the form users are able to remove the Configuration item field and then they can submit the request so hence in the request CI field will be missing so thiis needs to be avoided ..like this field should be mandatory......
also we tried adding it in the standard change proposal properties that was also not working as this Configuration Item field is a custom field
@Thousif S N
You can use onSubmit client script on that table; get the value of template field
Check if that string contains cmdb_ci value or not
Thank you it worked finally..
@Thousif S N
Glad that it worked.
Would you mind marking my response as helpful/correct if I am able to resolve your query?
