how to validate empty data in transform map?
jobin1
I need to validate below excel data while doing transform load (before loading to table)
Validation should be like if the bae64 data is empty then it should not allow to load data.
Ankur Bawiskar
@jobin
you can use onbefore transform script
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
	// Add your code here
	if(source.u_base64_data.nil())
		ignore = true;
})(source, map, log, target);
20 REPLIES 20
So what is not working?
if you are using onBefore then it should set the staging table field with the error message
@Ankur Bawiskar So the code which I posted is corrected you're telling?
Jobin
your code is already correct.
is it not working?
are you using correct field name for import set?
regards
Yes its  correct. I have passed empty bae64 data in excel but it created new record and "error reason" also not updated. Please find the screenshots.
inside each if statement you should be adding ignore=true;
