how to validate empty data in transform map?
jobin1
I need to validate below excel data while doing transform load (before loading to table)
Validation should be like if the bae64 data is empty then it should not allow to load data.
Ankur Bawiskar
@jobin
you can use onbefore transform script
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
	// Add your code here
	if(source.u_base64_data.nil())
		ignore = true;
})(source, map, log, target);
20 REPLIES 20
alert is client side and your script is server side
so please use gs.info() to check logs
@Ankur Bawiskar  gs.info() also used but not getting inside
the logic is correct
try to debug further
@Ankur Bawiskar  Below code is working and I have removed few validation now bae64 and file name validation only in place.
var cat_num = source.u_number;
var cat_item = source.u_item;
var fname = source.u_filename;
var ritmstate = source.u_state;
var contenttype = source.u_content_type;
var bae64 = source.u_base64_data;
//Source table map - ends here...
var category1,sub_category1,subcategory22,user_id,username,country,company,phone,assignment_group,company_sysid,asigntosysid,stateid,openstateid,rescatgsysid,clscode,urgcyvalue;
var errornote = " ";
var invaliderror = "";
var mandatoryerror = "";
var invalidmessage = "";
var statemessage = "";
var mandmessage = "";
if(source.u_base64_data == "")
ignore = true;
statemessage = "Missing Bae64data ";
errornote = statemessage;
source.u_error_reason = errornote;
if(source.u_file_name == "")
ignore = true;
statemessage = "Missing file name ";
@jobin
Glad to know that it worked.
