how to validate the output of a flow designer subflow in ATF test suite using run script option?
‎12-20-2023 09:25 AM - edited ‎12-20-2023 09:26 AM
hi
What can be the script?
‎12-20-2023 09:38 AM
‎12-20-2023 11:10 PM - edited ‎12-20-2023 11:22 PM
Hi Atul,
we are configuring a test Suite to validate Flow designer in the on one step using run script we want to vaildate the subflow that is configured whether the subflow is executing correctly or not. (like if the step result is success or not)
and can you tell me rom which table i can glide sub flow record? (on which table the subflows are stored)
‎12-21-2023 03:35 AM
Not possible through ATF
‎12-21-2023 05:07 AM
Thanks for sharing the update. I tried this but did not get any success on this part. See we need to test the functionality not the component. If the conditions match for subflow it will run else not and this is the way to test.
So in short, it is not possible in ATF.
