How to write a client script to calculate impact and urgency so that priority should autopopulate
Himabindu
Giga Contributor
How to write a client script to calculate impact and urgency so that priority should auto populate
Sample script as below.
	var getimpact=g_form.getValue('impact'); //replace impact  variable name
	alert('Impact user selected is '+getimpact); //Just for check can be commented
	var geturgency=g_form.getValue('urgency'); //replace urgency with variable name
	alert('Urgency user selected is '+geturgency); //for check can be commented
	if(getimpact=='high' && geturgency=='high')
			g_form.setValue('priority','high'); //replace priority with variable name & set the value as high
Note: You need to create 2 one for impact & other for urgency & replace variables & values accordingly.
9 REPLIES 9
@Himabindu Just to check did you mistakenly mark other answer as correct as it seemed you had marked some other answer correct.
Note: You can have only 1 answer correct so mark the one that helped & should help future readers.
Sir , what about the impact -1 & urgency 2 for getting priority 2...like that remaining value s as imp-1&urg 2 for pri-3 like that please give answer
Ankur Bawiskar
@Himabindu
For this you would require onChange client script on both the variables
1) Impact
2) Urgency
Hi Ankur, need some information can you message to my my id please. ranjithparam99@gmail.com
