How to write script in flow designer.
Sai25
I want to write the below code in flow designer,
var groupValue=gr.assignment_group.u_auto_close_duration;
var half = (groupValue/2).toFixed(2);
var roundingValue=Math.round(half);
var gDate = new GlideDate();
gDate.addDays(roundingValue);
gr.work_notes="This case has been marked Resolved. It will be auto closed on"+" "+gDate+" "+" if you do not take action.";
Here i want to write the script. Please help me how to write.
Thank You,
Sai.
hvrdhn88
Giga Patron
Create custom action here so scripting will be done in custom action, and then you will use that action in your flow designer.
Doc link for further details.
https://docs.servicenow.com/bundle/orlando-servicenow-platform/page/administer/flow-designer/concept...
Hi Asif,
Updated the script. Still getting the same error.
Mohit Kaushik
Hi Sai,
Change the first line as per Asifnoor's code to
var groupValue = fd_data.trigger.current.assignmment_group.u_auto_close_duration; //object should be fd instead of d
Mohit Kaushik
Mohit Kaushik
ServiceNow MVP (2023-2025)
Hi Mohit,
I changed it, but it still not working throwing an error.
Thank You,
Sai.
hvrdhn88
Giga Patron
