How to write wait for condition in flow designer based on request item variable value?
I have a request item where it we have a date field will select future dates after full filling first task second task should create when the date is matches with today date until then it should wait for condition to satisfy?
when I tried with wait for condition script its going forward in both return true and return false scenarios?
Runjay Patel
Hi @Community Alums ,
You can add wait for condition from and choose relative duration. give 1 minute and then select "after" and then choose your date variable.
In order to get the variable in above step you first need to call "Get Catalog Variable" and move date field variable right hand side.
Part 2. In this video i have talked about overview on ServiceNow platform/tool. How you can opt for personal dev instance (PDI)? how to login in ServiceNow instance and navigation to OOB modules. For document please visit: https://servicenowwithrunjay.com/ Follow Facebook page for latest update on
Runjay Patel
