How use a client script to check which fields were modified?
01-15-2026 08:42 AM
I am writing an onSubmit client script on the Incident table. The goal that it will perform a certain action if the form was modified, except in the case that only "assigned to" and/or "assignment group" are modified. I am currently using g_form.modified to check if anything was modified at all, but I am not sure how to verify that only those two fields are changing. Is there a way to determine which fields are changing without checking each one individually?
Thank you!
01-16-2026 07:18 PM
Hope you are doing good.
01-15-2026 09:59 PM
hi @EJ13
g_form.modified property is a binary switch—it only tells you that something changed, not what, to solve this without hardcoding every field, you need a "Snapshot Strategy."
Since g_form doesn't store previous values for you to access in an onSubmit script, you need two scripts
onLoad and onSubmit
function onLoad() {
g_form.initialValues = {};
var fields = g_form.getFieldNames();
for (var i = 0; i < fields.length; i++) {
var fieldName = fields[i];
g_form.initialValues[fieldName] = g_form.getValue(fieldName);
onsubmit
function onSubmit() {
if (!g_form.modified) {
var ignoreFields = ['assigned_to', 'assignment_group'];
var meaningfulChange = false;
if (ignoreFields.indexOf(fieldName) > -1) {
continue;
var currentValue = g_form.getValue(fieldName);
var originalValue = g_form.initialValues[fieldName];
if (currentValue != originalValue) {
meaningfulChange = true;
break;
// 5. Execute your Action
if (meaningfulChange) {
// YOUR CUSTOM CODE HERE
// alert("Significant fields were modified. Executing logic...");
Happy to help!
To help others in the community find this solution, kindly mark this response as the Correct Answer and Helpful.
Warm Regards,
Deepak Sharma
Community Rising Star 2025
