Need help for SC order status widget customization
03-17-2026 04:21 AM
Hi
Currently, when the request has been submitted in the service portal, it will be redirected to request summary and will show the RITM fields like "request number, item, stage". But as part of recent requirement, need to include some more fields like state & approval . To achieve this, I have cloned the OOB widget (SC order status) and trying to add the script but no luck. could anyone help on the customization/script where exactly it needs to be updated
Thank you
03-17-2026 06:02 AM
so where are you stuck?
you need to add logic in HTML and Server Side Script
03-17-2026 06:04 AM - edited 03-17-2026 06:05 AM
recently last month I shared solution for something similar with working screenshots
Steps to show it in column here
-> clone the OOTB widget "SC Order Status"
-> In the newly created widget, modify the server script etc to include Cat Item -> Short Description
check this link and it has solution, what to change in Server Script, HTML
Modify fields shown in SC Order Status widget -> this link will help you add in the place I mentioned above
-> then add this newly created widget on "order_status" page
if you want to add that on top besides the 3 columns then update the HTML place here
03-17-2026 06:06 AM
sharing other link which has some approach
SC Order Status add request short description
03-18-2026 01:40 AM
