if condition in UI page jelly script
samadam
I have two variables, one being set from syspam value and other from a query. I want to use them in a query based on if there is a value passed as parameter or if null use the value set in the g:evaluate.
This only works if syspam variable is populated. Using the test condition the value gets set but in the query it doesn't work. I tried to use "jvar_minc" insated of '${jvar_minc}' but this only works for one condition. How can I get this working. Is there a way to have if condition in g:evaluate?
<g:evaluate jelly="true">
  <j:set var="jvar_inc" value="${RP.getParameterValue('sysparm_inc')}" />
  </g:evaluate>
  var currentval = new GlideRecord('u_temp'); .addEncodedQuery('u_start_date&lt;=javascript:gs.daysAgoEnd(0)^u_end_date&gt;=javascript:gs.daysAgoStart(0)');
currntval.query();
currentval.next();
  var jvar_minc = currentval.q_val;
  </g:evaluate>
<j:if test="${!empty(jvar_inc)}">
  <j:set var="jvar_minc" value="${jvar_inc}" />
  </j:if>
  var inc = new GlideRecord('u_temp_table');
  inc.addQuery('u_inc_name', '${jvar_minc}');
  inc.addQuery('u_id', '${jvar_id}');
  inc.query();
  </g:evaluate>
when i print the values they come up right, its in the query it doesn't do the right evaluation.
Chuck Tomasi
Hi Sam,
You don't need a g:evaluate tag around the first j:set. g:evaluate is for running JavaScript. Also, when you use jelly="true", it says "I'm going to use a copy of the jelly variables", but you're not using them. Best practice is to avoid using ${variable} calls inside g:evaluate tags. You're half way there with jelly="true", but didn't use them. Finally, you had a hanging '.addEncodedQuery()" call with no object. Where did jvar_id come from? It is used in the second g:evaluate statement, but I don't see it set anywhere. Here's a cleaned up version of your script.
<g:evaluate var="jvar_minc" jelly="true">
  currentval.addEncodedQuery('u_start_date&lt;=javascript:gs.daysAgoEnd(0)^u_end_date&gt;=javascript:gs.daysAgoStart(0)');
  currntval.query();
  currentval.next();
  currentval.q_val;
  </g:evaluate>
  </j:if>
  inc.addQuery('u_inc_name', jelly.var_minc);
  inc.addQuery('u_id', jelly.jvar_id); // What is jvar_id???
  inc.query();
  </g:evaluate>
11 REPLIES 11
I finally got it to work with this
<g:evaluate var="jvar_forecasts" jelly="true" object="true" >
     var jvar_id = RP.getWindowProperties().get('ei_sys_id');
     gs.log('***jvar_id outside= ' + jvar_id);
     var arrForecasts = [];
     var grForecasts = new GlideRecord('u_ehs_forecasts');
     grForecasts.addQuery('u_forecast_parent', jvar_id);
     grForecasts.query();
</g:evaluate>
Thanks for your time,
Shannon
can you please tell me how to use between, >,< operators in g:evluate block using glide record.  None of them operators working.  The same operators work fine in server side scripts but not in g:evaluate block.
