If i share a Dashboard then user will not able to see the same Dashboard
01-04-2024 12:11 AM
If I share a Dashboard then user will not able to see the same Dashboard.
Dashboard has 10 reports as mentioned in the below screenshot, if i share the report user is not able to see the reports.
If i share it to the user with all the permissions then user is able to see 0 as mentioned below:
If i check the to click on 0 then i found that one extra condition has been added into it which is not there in my report.
Please let me know how to fix this?
01-04-2024 03:31 AM
Hi @kranthi2
Very wired case 😞 May be log a HI case or impersonate user (If not in prod) and check.
It may some cache issue, try cache.do
clear browser cache too.
01-04-2024 04:17 AM
It may some cache issue, try cache.do------------can i impersonate that user then perform this ?
clear browser cache too.: can i impersonated then can i do it ?
Please help me out the
01-04-2024 04:19 AM
NO NO
As you are admin
so do cache.do
Then If you are not in prod then impersonate with user and check.
01-04-2024 06:42 PM
Sorry it is not working even though i have done the cache.do
01-05-2024 03:49 AM
Hi @kranthi2
I doubt anything else we can do
Hope you checked
ACL on table level
and if last try to duplicate the correct report and add again in dashboard and shared with user. May be report get corrupted, or
Log a HI case.
