If state is resolved then send a notification and once enduser replyback to the same resolved nottfy
‎03-18-2025 04:32 AM
If state is resolved then send a notification and once enduser replyback to the same resolved notifiation then state should be auto closed.
I have done with the resolved notification but when i reply to the same email it is not auto closed.
I have tried in OOB inbound action script but still it is not working.
Can anyone please help on this, it will be usefull.
Thanks!
‎03-18-2025 06:09 AM
you didn't respond to my above question?
so is your inbound action getting processed or getting ignored? Did you add logs and verify?
Any other OOB inbound action on HR case table is being processed?
Any data policy is blocking the closure of HR case due to mandatory fields?
‎03-18-2025 06:14 AM
There is not data policies and scripts are bloking and i tried with logs and updated in the oob inbound action so now working.
Thanks for your guidence!
‎03-18-2025 06:17 AM
Hello @mania
Please accept solution or mark as helpful if any helped you, so that this thread can be closed and moved from unsolved to solved bucket.
Shivalika
‎03-18-2025 05:05 AM
Hello @mania
Easy thing to start your debug when you receive email, open email log check what processing has happen over your email under logs sections from there you will get to know did any other inbound process your incoming email or newly setup inbound took action or it was skipped.
Thanks & Regards
Viraj Hudlikar.
