Implementing Checklists on a Catalog Task
ravi_otpp
Hi SN Dev Community,
Has anyone been able to implement the Checklist feature on catalog tasks (eg. easy way for the task recipients to understand what needs to be done without multiple tasks)? Is there quick steps on how to implement this?
Ravi
ericgilmore
If you haven't found it, here it is.
How to automatically add a saved checklist to a task?
ty_roach
The problem with the OOB checklists is that they are unreliable, meaning, people can change the content of the checklist item after the fact, add items, delete items, change items.  There's also no guarantee that the same checklist will appear for same situation.  There is no way to restrict who can edit the checklist or when it can be edited (like do you really want people changing checklist responses after the record has been closed).
Enter Checklist Pro.  We built Checklist Pro to solve all those problems and more.  Checklist Pro application administrators can define when checklists get created and associated with records in a table (any table - not just those that extend TASK), when these checklists can be edited, when the associated record is considered "closed" (and thus should prohibit further checklist updates).  We even added the ability to define "Required" checklist items that allow enforcement, thereby preventing a record from closing unless the required items are completed.  We've built convenience Database Views to go with the most common checklist tables, which include TASK, SYSAPPROVAL_APPROVER, CMDB_CI.
They work in the Service Portal as well as in the Classic UI.
They'll work with other Scoped Applications (like HR or SecOps or even custom scoped apps & tables).
For more information contact TyGR LLC or goto our youtube channel to see it in action.
