in ATF while i am creating ATF in the Set Variable values (SP) i can't see the solution type
kranthi2
in ATF while i am creating ATF in the Set Variable values (SP) i can't see the solution type, where as i can see it in the manually.
Please find the below ATF test.
Please help me out with the reason.
@kranthi2
The client test runner should be open throughout the retrieval process.
Shaqeel
If my response proves useful, please indicate its helpfulness by selecting "Accept as Solution" and " Helpful." This action benefits both the community and me.
Shaqeel
Sure, let me try this from my side.
I will keep you update the results.
Once completed the Set component value step it is showing the above window which should i select here.
Please help me on the same.
