In Flow Designer, for order task i want to auto populate assign to field is current logged in user
nidhi40
Hi All, In Flow Designer, for order task i want to auto populate assign to field is current logged in user. any one help me on that.
Ankur Bawiskar
@nidhi40
Please discuss with your customer what do they mean by logged in user
are they referring to the user who raised the RITM?
if yes then do this
return fd_data.trigger.request_item.request.requested_for;
13 REPLIES 13
Yes Ankur I discussed with customer, requirement is
For product order task is created assigned to field is auto populate current logged in user
I used below code
return gs.getUserDisplayName();
When I was open the execution details assign to name is showing but in order tasks assigned to field is showing empty.
@nidhi40
where are you writing that script?
In flow designer While creating the order task action I selected Assigned to >scripted expand to edit in that iam writing the code
@nidhi40
if you had a discussion with customer then what's the outcome
Who is the logged in user?
Because when flow runs it can run as system user or user who initiated the session
I already shared yesterday the point
if yes then do this
In flow designer While creating the order task action I selected Assigned to >scripted expand to edit in that iam writing the code. Outcome is current logged in user?who initiated the session
