In Flow designer, how to add auto-approval after 30 days on a Catalog form
AbdurRahmanSnow
Good evening. I have a requirement that, on a Catalog Form, we have one approval, through Flow Designer.
So, assume, if 30 days passed, then it should get auto-approved?
How can we do this? (Screenshot attached below)
2 ACCEPTED SOLUTIONS
Viraj Hudlikar
Tera Sage
Hello @AbdurRahmanSnow
Before that ask for approval action add a wait for timer action for 10 seconds is fine.
In that approval action do you see due date field open it and select approve option then if pending by relative 30 from wait for duration. See screenshot:
Thanks & Regards
Viraj Hudlikar.
AbdurRahmanSnow
Correct answer: I did not use Wait for condition 10 seconds. Just used @Viraj Hudlikar answer.
11 REPLIES 11
Voona Rohila
Hi @AbdurRahmanSnow
Adding to others, Make sure you add proper conditions ( Auto Approve/Reject for Specific catalog items only) or this will affect all the other Approvals too(Change,Standard Change etc..)
Viraj Hudlikar
Tera Sage
Thanks & Regards
Viraj Hudlikar.
Viraj, thank you so much for this. Just wanted to ask, how will this Flow run?
If someone approves, will it still wait for 30 days or proceed ahead?
If approval actions takes place which can approve or reject then it will proceed ahead if no action taken then auto approval will take place.
AbdurRahmanSnow
