In Flow designer, how to add auto-approval after 30 days on a Catalog form
AbdurRahmanSnow
Good evening. I have a requirement that, on a Catalog Form, we have one approval, through Flow Designer.
So, assume, if 30 days passed, then it should get auto-approved?
How can we do this? (Screenshot attached below)
2 ACCEPTED SOLUTIONS
Viraj Hudlikar
Tera Sage
Hello @AbdurRahmanSnow
Before that ask for approval action add a wait for timer action for 10 seconds is fine.
In that approval action do you see due date field open it and select approve option then if pending by relative 30 from wait for duration. See screenshot:
Thanks & Regards
Viraj Hudlikar.
AbdurRahmanSnow
Correct answer: I did not use Wait for condition 10 seconds. Just used @Viraj Hudlikar answer.
11 REPLIES 11
The reason I added wait for 10 seconds as I didn't know what you have in your flow previous step, I usually add it as it has help me many times. I am glad it was helpful to you and all folks who will see this solution to use while designing flow.
Thanks & Regards,
Viraj Hudlikar
Oh I see. No problem. Once again, thank you so much, Viraj.
