In ServiceNow Background Script without using addEndcodedQuery how to apply multiple filters
SreenadhChenna
In ServiceNow Background Script without using addEndcodedQuery() how to apply multiple filters.
If i want to run a Background script in the incident table i want to fetch last 15days incidents which has created and Active=true but i don't want to use addEncodedAQuery()
Siva Jyothi M
Hi @SreenadhChenna,
gr.addActiveQuery();
gr.addQuery("sys_created_on",'<',gs.daysAgo(15));
while(gr.next()){
    gs.print(gr.number);
//gs.print(gr.getRowCount());
Mark this answer as correct and helpful if it solves your issue.
Siva Jyothi M.
Ravi Chandra_K
Hi @SreenadhChenna
Try gr.addQuery('sys_created_on','<',gs.daysAgo(15));
please mark the answer as correct and helpful if helped!
Kind Regards,
Ravi Chandra
Ankur Bawiskar
@SreenadhChenna
then you need to run the query and inside while loop check the comparison i.e. get difference of current time and sys_created_on and if it's 15 then do your logic.
It's always recommended to use encodedQuery wherever possible to reduce the number of records at the first level itself
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
Siva Jyothi M
Hi @SreenadhChenna,
while(gr.next()){
Siva Jyothi M.
