Info Popup
Sidhu9
Hello Experts,
How to Add Info PopupPW.JPG, for Reference please check attachment.
Srinu
Thanks& Regards
Sidhu !
Hi Madhan,
I want to add this type of popup for one of String filed in the change form.
Thanks& Regards
Srinu
Thanks& Regards
Sidhu !
Hi @Sidhu9 ,
Preview record is available oob on all reference fields. When you select a record after that you can just hover on the i icon and preview the record.
OR
Go to the URL below and right click on the form and select configure layout like you normally would, that will change the form layout for the popup view.
<your instance name>.service-now.com/<table name>.do?sysparm_view=sys_popup
OR
You can add an attribute to the field to make this possible.
https://docs.servicenow.com/bundle/rome-platform-administration/page/administer/field-administration/concept/c_ReferenceIcon.html
Configure the dictionary entry and add the readonly_clickthrough=true attribute.
Thanks & Regards,
Sumanth Meda
