01-16-2024 08:19 PM
Hi All.
I'm newvy in servicenow ITSM.
Our team want to use e-mail and teams chat for creating and checking instances.
E-mail setting is fine but i have some trouble with teams.
I already make instance to notify incident creation. Please check image.
This is my question.
Is it possible to create Incident in teams chat similar to e-mail inbound action?
I want to create incident by inputing "our system is down" on teams chat.
BR.
01-16-2024 11:08 PM
Hi @Hank Woo
To create an incident from Microsoft Teams chat in ServiceNow, you can use the Teams Integration with Incidents feature in ServiceNow. This integration allows you to start a new chat from the Incident form using Microsoft Deep Link and UI Macros.
Here are the steps to create an incident from Microsoft Teams chat in ServiceNow:
Activate Microsoft Teams as a chat provider in ServiceNow. You can navigate to "Major Security Incident Management > Chat Provider Configuration" and select the Microsoft Teams record. Reference
Identify the appropriate event or condition that triggers the group chat initiation. Write a business rule script in ServiceNow that executes the chat initiation when the condition is met. Reference
Configure the Teams Integration with Incidents to start a new chat from the Incident form. This involves using Microsoft Deep Link and UI Macros. Reference
By following these steps, you will be able to create an incident in ServiceNow by inputting the system issue in Microsoft Teams chat.
Please mark this response as correct and helpful if it helps
01-17-2024 09:09 PM
Thanks @Dr Atul - LNG
I also activate "Major Security Incident Management", then I can find Major Security Incident Management > Chat Provider Configuration.
01-18-2024 09:04 AM
