BR runs for some admin users and not for others !
01-18-2024 03:15 AM
Hi ,
I have a before Business Rule on the table 'problem' with error msg displayed that prevents the change of state from 'open' to 'resolved' or 'closed' if the problem still have open tasks . There are no conditions based on the role or user in the BR. The issue is that in list view ,when I run my tests, the BR works as expected on form and list and does not allow the closure of a problem with open tasks but when the client tests it, he's able to close the problem in list view mode. We both have an admin role. I want to know if there are cases that override the BR, such as role-specific or other scenarios, that give him the possibility to change on list view and not execut the BR?
Thank you
01-18-2024 03:17 AM
Can you please share your BR configuration?
Also have you tried impersonating another user and tested same scenario?
01-18-2024 06:27 AM - edited 01-18-2024 06:50 AM
Hi @Anil Lande ,
Itried to impersonate with many users , aNd it works but ,only one "admin" user can edit from the list view . It's a simple BR before update on problem table, with 2 filter conditions (state is resolved OR state is closed) with the following code :
var gr = new GlideRecord('problem_task');
gr.addActiveQuery();
gr.addQuery('problem',current.sys_id);
if (gr.next()) {
gs.addErrorMessage(gs.getMessage('Check_Prbtask_Resoled'));
current.setAbortAction(true);
})(current, previous);
I dont know if he has a role that override the BR , is that even possible? because we have both admin role but the BR works for me and not for him ?
01-18-2024 03:18 AM
