is it possible to send attachment through transform map?
jobin1
Hi All
My requirement is business will be encoding the attachment and sending that encoded value in excel format and the same we need to decode and transfer to ritm form via transform map.
So is it possible to do so? if yes how?. what transform script we need to use to achieve this functionality
So you can use this in global scope
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
	// Add your code here
	var fileName = source.u_file_name;
	var fileContentType = source.u_content_type; // such as image/jpeg or application/pdf
	var fileData = source.u_base64_data;
	var ecc = new GlideRecord('ecc_queue');
	ecc.initialize();
	ecc.agent = "AttachmentCreator";
	ecc.topic = "AttachmentCreator";
	ecc.name = fileName + ":" + fileContentType;
	ecc.source = target.sys_class_name + ":" + target.sys_id;
	ecc.payload = fileData;
	ecc.insert();
})(source, map, log, target);
32 REPLIES 32
@jobin
Glad to know.
I think you should mark this response of mine as correct so that it helps future readers
Please mark response helpful as well.
@Ankur Bawiskar  Done.
@Ankur Bawiskar  I am attaching the attachment which is got attached to RITM but conversion is not happening when I download the file it is still in encoded format. Please find the screen shots
attached attachment.
While opening attachment /still in encoded format.
Data which we uploaded.
do this
use writeBase64() method instead of write()
	var sa = new GlideSysAttachment();
	sa.writeBase64(target, fileName, fileContentType, fileData);
@Ankur Bawiskar  Its not working. its still not decoding
