02-08-2022 02:56 AM
Hi All
My requirement is business will be encoding the attachment and sending that encoded value in excel format and the same we need to decode and transfer to ritm form via transform map.
So is it possible to do so? if yes how?. what transform script we need to use to achieve this functionality
Request Management
03-02-2022 06:34 AM
So you can use this in global scope
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
// Add your code here
var fileName = source.u_file_name;
var fileContentType = source.u_content_type; // such as image/jpeg or application/pdf
var fileData = source.u_base64_data;
var ecc = new GlideRecord('ecc_queue');
ecc.initialize();
ecc.agent = "AttachmentCreator";
ecc.topic = "AttachmentCreator";
ecc.name = fileName + ":" + fileContentType;
ecc.source = target.sys_class_name + ":" + target.sys_id;
ecc.payload = fileData;
ecc.insert();
})(source, map, log, target);
03-02-2022 02:36 AM
it should work if the base64 data is correctly encoded one.
03-02-2022 03:05 AM
When i use ->sa.writeBase64(target, fileName, fileContentType, fileData);
even file is not getting attached.Also i used https://www.base64encode.org/ online tool for encoding
my script.
onafter
var sa = new GlideSysAttachment();
//sa.write(target, fileName, fileContentType, fileData);
03-02-2022 03:13 AM
are you in scoped app or global scope?
03-02-2022 03:26 AM
03-02-2022 03:42 AM
How did it get attached earlier then when you added the reply?
