is it possible to send attachment through transform map?
jobin1
Hi All
My requirement is business will be encoding the attachment and sending that encoded value in excel format and the same we need to decode and transfer to ritm form via transform map.
So is it possible to do so? if yes how?. what transform script we need to use to achieve this functionality
So you can use this in global scope
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
	// Add your code here
	var fileName = source.u_file_name;
	var fileContentType = source.u_content_type; // such as image/jpeg or application/pdf
	var fileData = source.u_base64_data;
	var ecc = new GlideRecord('ecc_queue');
	ecc.initialize();
	ecc.agent = "AttachmentCreator";
	ecc.topic = "AttachmentCreator";
	ecc.name = fileName + ":" + fileContentType;
	ecc.source = target.sys_class_name + ":" + target.sys_id;
	ecc.payload = fileData;
	ecc.insert();
})(source, map, log, target);
32 REPLIES 32
@Ankur Bawiskar  Great you're code is working. But having issue when I am trying to decode 2 ritms in single load that means decoding is happening only for 1 RITM in excel.
Ending with 06 decoded correctly but for 74 noting attached in RITM
if it worked for 1 row then it should work for other as well
try to debug for that RITM in sys_attachment any file is present or not
@Ankur Bawiskar Sorry i missed to give file type and content type now its working .Thanks Ankur
Hi ankur
I used your code in transform script.
But After opening the attachment, I am not seeing the data in any pdf,word,excel file and I am seeing the data in text files.
After downloading the pdf file, I am seeing the empty content
Original file
Can you give me the solution for this, please.
Raju Manga
@Community Alums
it has worked for other member earlier.
are you sure you are sending correct base64 data?
