is it possible to send attachment through transform map?
jobin1
Hi All
My requirement is business will be encoding the attachment and sending that encoded value in excel format and the same we need to decode and transfer to ritm form via transform map.
So is it possible to do so? if yes how?. what transform script we need to use to achieve this functionality
So you can use this in global scope
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
	// Add your code here
	var fileName = source.u_file_name;
	var fileContentType = source.u_content_type; // such as image/jpeg or application/pdf
	var fileData = source.u_base64_data;
	var ecc = new GlideRecord('ecc_queue');
	ecc.initialize();
	ecc.agent = "AttachmentCreator";
	ecc.topic = "AttachmentCreator";
	ecc.name = fileName + ":" + fileContentType;
	ecc.source = target.sys_class_name + ":" + target.sys_id;
	ecc.payload = fileData;
	ecc.insert();
})(source, map, log, target);
32 REPLIES 32
@Ankur Bawiskar
I am attaching the detailed information what I have done in 2 instances.
In instance 'A' I used this business rule
And I am sending the attachment infomation onto staging table in instance 'B'
Here I am getting the encoded information like this:
After that I wrote the transform script which you mentioned by doing some changes
Are you seeing any mistakes in these things. Can you check it once, Kindly please?
Raju Manga
@Community Alums
can you create a new question and tag me there and include all the details?
This thread is quite old.
@Ankur Bawiskar
ok
Raju Manga
