Is there a response template limit on Agent Workspace?
YenGar
Hello all,
Is there a response template limit on Agent Workspace? I have 14 templates tied to the Interactions table and can be used in Agent Chat but I have noticed that not all of them are visible. They are in alphabetical order by the short name but only 9 show up for the agent to select. I have made sure that they are all visible to the agents and they all can see them but not all of the available templates. There is no scroll bar either to scroll down to see more. Not sure if this is controlled anywhere or how to change it.
response templates:
From list view:
Does anyone have any suggestion / idea on  how to fix this?
Thank you so much!
Yeny
Pranesh072
update the following property com.glide.quickactions.maxresults.templates
Thanks Pranesh, super helpful information.
