Is there a way to convert a Catalog Item to a Record Producer
rachelturkariga
Giga Contributor
I have a 3 catalog item but i wanted them to a Record Producer now. Since there are many variables and is there any easy way to create it rather than manually creating a record producer again.
Thank You Team.
Appreciate all your Help.
No worries Rachel.
Glad that the solution have worked out. But I was the first 🙂
When I run this, the system creates a blank Record Producer record.
Is the catalog item supposed to be converted?
rachelturkariga
Giga Contributor
Thank You  Sachin, Pradeep and Jaspal.
This is working Fine.
Unfortunately i can mark only One of your answers as Correct. So , i have to mark Sachin's answer  as Correct . Since he is the First one to answer.
Really appreciate your Help Pradeep and Jaspal.
Thank You so much.
No worries Rachel.
Oops Sorry then , i have marked your answer as correct.
