Is there a way to use a Dictionary Entry Calculated value to total a related list
Christopher Dan
I have a related list on a form that I need a currency column to total up to a field on the form. I want to use a Dictionary Entry Calculate Value to total so it totals instantly without an update to the record of the related list. Is this possible?
21 REPLIES 21
I doubt onchange will trigger for the calculated field,
You can write a simple onChange script for the actual cost field and print an alert statement and see if changing the values on the forms, will trigger the onchange or not.
which table would I put it on? and what other way could I get it to update correctly if I don't use a onchhange script?
I have just constructed a table in my local instance,
Two variables
Name // this variable holds the name
Calculated Name //this variable is calculated which gets value from the Name field
Ex:
Name = Chris
Calculated Name gets calculated to value = Hi Chris
Written a before BR which triggers on Calculated Name field
On updating the Name field with Chris Danko
Calculated Name gets calcualted to value = Hi Chris Danko
The BR is triggering
So I am not sure now, why the BR that you have written on the Work Order Cost on change of Actual Cost is not triggering.
If its your developer instance, I can help you in debugging by logging inside.
it is my Dev instance
Cool, can you create a new user like
Username: admin2
Password: Test@123
Give the user admin role, give me details of the tables, I will try to take a look into it
