11-17-2025 03:00 AM
Is there any functionality in flow to run custom script as Run script activity in workflow ? When condition matches I want to trigger a script in flow designer.
Thank You
11-18-2025 10:41 PM
you can add 2 script steps in same custom action or have 2 custom actions with 1 script step in each of those
it's as per your customer requirement.
11-19-2025 03:24 AM
no we can't use current object in Flow action script.
pass the record sysId as input to flow action, then in script step query that table with that sysId and then use that GlideRecord object
I believe I answered your original question.
11-20-2025 01:17 AM - edited 11-25-2025 06:53 AM
Hi @Ankur Bawiskar ,
I was configuring as you suggested but not sure why there is no option is coming to select in data pill. Can I try to pass through script ? Could you please help with the script ?
Thank You
11-20-2025 01:43 AM
11-20-2025 03:34 AM
11-20-2025 03:38 AM
Step 4 is OOTB action or custom flow action?
what are you trying to pass to that action?
