Is there any functionality in flow to run custom script as Run script activity in workflow ?
1_DipikaD
Is there any functionality in flow to run custom script as Run script activity in workflow ? When condition matches I want to trigger a script in flow designer.
Thank You
@1_DipikaD
you can add 2 script steps in same custom action or have 2 custom actions with 1 script step in each of those
it's as per your customer requirement.
23 REPLIES 23
@Ankur Bawiskar ,
OOB function , I am trying fetch the sysid of the record in cmdb_ci table and passing the sysid of that list collector value which is captured in 1st step as mentioned in below pic .
Actually it was a workflow and in that only 2 run scripts are there and a set value activity is there and the workflow ends. I am migrating the exact logic to flow and will deactivate the workflow. I have provided the script could you please suggest if I am doing correct or need follow any other method ?
Thank You
@1_DipikaD
then it should work as you should be able to select the list collector
that list collector is referring to some table or to question_choice?
@Ankur Bawiskar ,
That list collector is referring to cmdb_ci table .
@1_DipikaD
then it should work fine.
Hi @Ankur Bawiskar @yashkamde ,
Can we use fd_data instead current object . If yes then could you please help me with the script ?
Thank You
