Is there any functionality in flow to run custom script as Run script activity in workflow ?
1_DipikaD
Is there any functionality in flow to run custom script as Run script activity in workflow ? When condition matches I want to trigger a script in flow designer.
Thank You
@1_DipikaD
you can add 2 script steps in same custom action or have 2 custom actions with 1 script step in each of those
it's as per your customer requirement.
23 REPLIES 23
@1_DipikaD
it's very simple.
pass the record sysId to custom flow action as input
then use that to query your table and you have the GlideRecord object of that record
Yes,
In flow designer while using actions we have the option for toggle script there we can use fd_data object and write our script..
If this help please mark as helpful..
MaxMixali
Yes, Flow Designer can run custom scripts!Main Options:
Script Step (inline in flow) - Most similar to Workflow "Run Script"
Custom Script Action (reusable)
Script Include (called from Script Step)
Subflow with Script (for complex reusable logic)
yashkamde
Tera Sage
Use a Script Step inside an Action
1) Go to Flow Designer → Actions
2) Create a new Action
3) Add a Script step
--> This allows running custom server-side JavaScript
--> You can define inputs & outputs
4) Save the Action
5) Use that Action inside your Flow
