Issue in flow design
08-24-2026 10:38 AM
I have created a field in a Catalog Item and configured a UI Policy so that the field is visible only on the Catalog Task (sc_task) form and not on the RITM or REQ forms.
My requirement is that when a user selects a value in this field on the Catalog Task, another Catalog Task should be created automatically based on the selected choice value.
However, I am facing an issue where I am unable to fetch the field value in Flow Designer. Since the field is available on the Catalog Task, I would like to know the best approach to access this field value in the flow and use it to create another task.
Could you please suggest how to fetch the Catalog Task field value in Flow Designer and use it in a condition for creating a subsequent task?
Thanks and Regards,
Veeresh
08-25-2026 12:56 AM
