Issue in Populating response Body in ticket Creation AP
Vamshi_ch123
Hello everyone,
I'm attempting to populate the response body with the ticket ID when a customer creates a ticket using the shared API. I've created a REST API script for this purpose, but I'm encountering an issue where I'm receiving a status code 200, but the response doesn't contain the ticket number or any accompanying message."
(function process( /*RESTAPIRequest*/ request, /*RESTAPIResponse*/ response) {
   this.status = '200';
   var respObj = {};
  var payload = request.body.data;
var caller_id = payload.callerid;
var environment = payload.Environment;
var category = payload.Category;
var priority = payload.Priority;
var short_description = payload.Summary;
var description = payload.description;
var id = payload.W_Ticket_ID;
    var gr = new GlideRecord("sn_customerservice_case");
    gr.initialize();
   gr.short_description = short_description;
    gr.priority = priority;
	gr.category = category;
	gr.environment = environment;
	gr.u_ticket_id = id;  gr.description = caller_id + "\n" + priority + "\n" + environment + "\n" + short_description + "\n" + description + "\n" + id + "\n" + product + "\n" + account;
    gr.insert();
        respObj.body = {
            "message": "Creation Success!",
            "detail": "Case " + gr.number + " created successfully"
})(request, response);
Hi @Vamshi_ch123
I tried the following code in my PDI and it is working fine (see the screen shot, please try this code for one more time.
    var respObj = {};
    gr.initialize();
    gr.insert();
    var case_number = gr.getValue('number') + '';
    var resp_data_obj = {
        message: "Creation Success!",
        detail: "Case " + case_number + " created successfully"
    return resp_data_obj;
Anvesh
9 REPLIES 9
Hi @Vamshi_ch123
    var respObj = {};
    gr.initialize();
    gr.insert();
Anvesh
this worked thank you
Ankur Bawiskar
@Vamshi_ch123
you are writing the above code inside scripted rest api so it means ServiceNow will receive the request and will send response.
Are you sure the case got inserted? any BR is getting blocked?
try to use try catch block to see the exception
	try{
		var respObj = {};
		gr.initialize();
		gr.insert();
		var resp_data = {
		response.setBody(JSON.stringify(resp_data));
	catch(ex){
		gs.info(ex);
Hi @Ankur Bawiskar ,
Yes case getting inserted but the response message is not showing up.
@Vamshi_ch123
what type of http method you created? post?
script looks good to me
