Issue on Dynatrace integration
GianluNow
Mega Expert
Has anyone ever done integration with dynatrace application? I've an issue connection.
I've done integration following this guide : https://www.dynatrace.com/support/help/setup-and-configuration/integrations/third-party-integrations/problem-notification-systems/servicenow-integration/#automatic-configuration-check
When I try to test connection i've this problem :
My istance is on Madrid version. I can't find appservice script include indicated on point 3. Maybe is these the cause of issue?
Has anyone already done that?
Thanks.
HI,
This is not serviceNow issue tough. It has to do something with Dynatrace. They have to see if they support you instance version, other things,etc.
Ashutosh
Rajesh155
Did you find any solution of the above issue ?? We are observed the same error however connection was successful. but not receiving the events 😞
Eric Smith
did you solve it? i suppose you're not using any external help to connect the two - i mean, add-on/connector. have you considered it as an option? i ask, because i use such a tool (zigiops) to integrate them.
