02-24-2022 01:38 AM
I used the below code, to generate access token with refresh token, from the below code I am getting access token but for refresh token I am getting "NULL" what is the reason for it? any idea?
username and passwords are correct only and also passed correct application registry
var oAuthClient = new GlideOAuthClient();
var params ={grant_type:"password", username:"itil", password:'itil'};
var json =new JSON();
var text = json.encode(params);
var tokenResponse = oAuthClient.requestToken('TestClient', text);
var token = tokenResponse.getToken();
gs.log("AccessToken:"+ token.getAccessToken());
gs.log("AccessTokenExpiresIn:"+ token.getExpiresIn());
gs.log(" RefreshToken:"+ token.getRefreshToken());
02-24-2022 04:17 AM
02-24-2022 03:57 AM
In step 7, i am getting "NULL" value for refresh token
02-24-2022 04:01 AM
Have you followed exactly what I have mentioned in Step 6 .?
Step 6 is driving Step 7 and is working correctly for multiple scenario I have tested.
Share your steps one after the other to assist you further
Shloke
02-24-2022 04:15 AM
Verified everything, in step 5 under variable substitution I can't see access token..remaining all are same.
02-24-2022 04:17 AM
02-24-2022 04:45 AM
Couple of things here you need to do :
1) In the Rest message under HTTP Request tab make sure you have the below configurations done as shown below:
Save it first and now if Variable Substitution is not present then create one exactly similar to shown in screenshot.
Shloke
