Issue with setting RITM stages in flow designer
pramodkumar
I am trying to set RITM stages and state in flow designer. When task is closed incomplete,  I have used update record to update state to closed incomplete and updated stage to closed complete. But in activity, I see state first updated closed completed and then to incomplete.
What is the correct of updating stages and states of RITM from flows?
Thank you!
SAI VENKATESH
Hi @pramodkumar
In your scenario you can change the state before state is getting updated.
Here is the example to create stage in flow designer.
Thanks and Regards
Sai Venkatesh
