Help on flow designer
Tanya10
Hi All
i have a use case where I have to send the reminder to end user on 3 and 5 day if incident is on hold and awaiting caller response.
i have used do following until but it is not working as expected. I’m facing issue when the incident state is changed to in progress before 3 days or assume 4 day. I expect flow to cancel rather than waiting for 3rd or 5th day then cancel. Any suggestions
YaswanthKurre
Hi @Tanya10 ,
Use state in condition in wait for along with time line
  1. Trigger: When Incident is updated and state is set to On Hold and substate is Awaiting Caller Response
  2. Wait for Condition: (Action not flow logic).
    • Wait until State is not On Hold OR Substate is not Awaiting Caller Response
    • Duration: 3 days (72 hrs)
    • If the condition is met before 3 days → wait foe ends and moves to next steps check condition again and not on hold cancel it.
    • If timeout occurs → Send 3-day reminder ( based on state validation), use if else.
Mark this as helpful and correct if this helps you.
yaswanth
@Tanya10 this looks fine, for the testing purposes set the timer to minutes to see the behaviour
Hi
but i gave to wait from the time incident went on hold and then calculate if 3 days passed or 5 days. This on hold time is custom field
Hi @Tanya10 ,
You  don't really need a custom field for this, as this flow will trigger directly when it went on on hold, so time will be calculated 3 days from it went on Hold.
you can get rid of that field.
