Issue with while opening a particular catalog item RITM/SCTASK request it is taking longer time to l
rajasekar reddy
Hi ServiceNow experts
@Ankur Bawiskar
Issue with while opening a particular catalog item RITM/SCTASK request it is taking 5 to 7mints time to load.
I have checked catalog item there 50 variable are there out of 50 there are 10 variable with type of " reference ", because this it is getting time load  RITM/SCTASK.
Can anyone help me to fix the issue?
Hi @Peter Bodelier  @Peter Bodelier ,
Found the issue due to 5 variable with type of " reference " with the same table "sys_user_group" and 5 variable with type of " reference " with the same table " sys_user " ,There are 25 UI policy actions linked to. one UI policy.
do you have any idea idea how to fix the issue?
That really depends on your use case for this setup. I really can't help without knowing your use case, and insights what you have built.
Help others to find a correct solution by marking the appropriate response as accepted solution and helpful.
