09-30-2025 10:41 AM
Hello Team,
I have a requirement :
I am submitting the request and there we have certain approval after the creating the change request from the Run Script activity of the workflow in that workflow i want to wait till change request state should move to implement state and once Change moves to implement then calling API for Integration.
Most of the thing are working as expected but only wait for condition is not working. i tried many approaches:
1. When ever wait for condition is triggering then executing first time and returning the new value but i want implement state value.
2. Wait for WF Event : this activity i used eventQueue & gs.eventQueueScheduled, Created event in event registry and triggering the event by Business Rule , Same event name passed in activity . before and after eventQueue info is generating but not moving in next activity.
gs.info("BR 1 ");
if (current.state.changesTo(-1)) { // Replace 3 with your "Implemented" state value
var journalGR = new GlideRecord('sys_journal_field');
journalGR.addQuery('element_id', current.sys_id);
journalGR.addQuery('element', 'work_notes');
journalGR.orderByDesc('sys_created_on'); // Get latest note first
journalGR.query();
while (journalGR.next()) {
var note = journalGR.value.toString();
gs.info("Work Note: " + note);
var match = note.match(/RITM Reference:\s*([a-f0-9]{32})/);
gs.info("BR 2 "+match);
if (match && match[1]) {
var ritmGR = new GlideRecord('sc_req_item');
if (ritmGR.get(match[1])) {
gs.info("Firing event on RITM: " + ritmGR.number);
gs.eventQueueScheduled('change.implemented', ritmGR, ritmGR.sys_id, ritmGR.number);
gs.info("Firing event on RITM after " + ritmGR.sys_id);
gs.error("RITM not found for sys_id: " + match[1]);
break; // Stop after first match
})(current, previous);
I need help on Wait for condition step.
Workflow is created in RITM Table and I want wait for change request.
Please let me know if you need any additional information.
Thanks a lot in advance and your support will be appreciate.
Sanjay Bagri
09-30-2025 10:41 PM
Since workflow is on RITM and you want to create CHG and wait till CHG moves to Implement State, The wait logic won't work directly.
See this workaround which I shared -> you need BR on CHG table when State Moves to Implement which broadcasts the Workflow to proceed.
You need RITM stored on CHG then only you know which workflow to broadcast the message
I shared solution 5 years ago, see that and enhance
Approval Wait for Condition Stuck and will not move forward
10-03-2025 05:55 AM
Thanks @Ankur Bawiskar , I got the solution and its working as expected.
