java.sql.BatchUpdateException: (conn=*****) Duplicate entry '3c4464a7b701230034d1da2*******' for key 'PRIMARY'
srinidhi
Hi Team,
Unable to import the xml's getting below error. Please refer the screenshot. Please let me know how to resolve this
Thanks.
Check with the same sys_id on the table, there must be some existing record, which is causing this behavior.
You can use this script as well, to see which record corresponds to this sys_id:
https://community.servicenow.com/community?id=community_question&sys_id=bda11b6ddbdcdbc01dcaf3231f96...
Best Regards
Aman Kumar
Thanks @Aman Kumar, checked the sys_id and found the duplicate onces.
