JavaScript - calculate number values in a string
Paul125
I am working on a script where I need a read an output and calculate the numbers at end of each line. I am trying the below script but I am unable make it further.
Note: script should be able to add values of 'Local Fixed disk' ONLY.
Output I get in the ecc queue:
Caption  Description       Size
C:       Local Fixed Disk  64422408192
D:       Local Fixed Disk  999645245440
G:       CD-ROM Disc       99884729
Script to read and calculate the size
//I pasted the above output in the Incident short descripion to make script running easier.
gr.get('number','INC7914138');
var output= gr.description;
var lines = output.split('\n');
var diskSpace = 0;
for (var i = 0; i < lines.length; i++)
	var newArray = lines[i];
	if (newArray.indexOf('Local Fixed Disk'))
		var n = newArray.split(" ");
		var disk = (n[n.length - 1]);
		diskSpace = diskSpace + parseInt(disk);
		gs.print(diskSpace);
Expected output:
//addition
64422408192+999645245440 = 1064067653632
11 REPLIES 11
Thanks for the reply Cody.
Output
*** Script: NaN
*** Script: NaN
*** Script: NaN
*** Script: NaN
*** Script: NaN
*** Script: NaN
*** Script: NaN
*** Script: NaN
Paul,
It looks like you're passing a string into your "parseInt(disk);"
Could you print out what you're passing as 'disk'? You will need to make sure those are numbers.
Cody - this is what I get.
*** Script: 64422408192
*** Script: 999645245440
vkachineni
//Tested on PDI
//if (newArray.indexOf('Local Fixed Disk') > -1) changed this line
var output= "Caption Description Size\nC: Local Fixed Disk 64422408192\nD: Local Fixed Disk 999645245440\nG: CD-ROM Disc 99884729";
var diskSpace = 0;
//gs.info("newArray toString" + lines.toString());
//gs.info("newArray =" + i + " = " + newArray);
var disk = (n[n.length-1]);
*** Script: 1064067653632
Paul125
Thanks for the reply. Can I limit the output to below? Just additions of disks.
