Knowledge Feedback Task is going to Default Assignee
sayan-ghosh
Hello Team,
Whenever I am submitting the Knowledge Feedback Task.
The Task is assigning to Particular Knowledge Group Default Assignee.
But the Requirement is The Assigned to needs to be Empty
Created Client Script:
Please Help me to achieve this.
Best Regards
17 REPLIES 17
When A Knowledge feedback Task is submitted , Then It should go to "Knowledge Management Group" and Assigned to Should be Empty.
But In assigned to It is Taking Knowledge Management Group Default Assignee
Hi @sayan-ghosh
Instead of Client script, please create a after insert BR on kb feedback table and try to clear the assigned to when assignment group is "Knowledge Management Group".
When to run condition should be Assignment group is "Knowledge Management Group".
Please test it on non prod instance once.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this question to solved bucket.
Prathamesh
Used a BR
Still Taking the Knowledge Group Default Assignee
Hi @sayan-ghosh
It should be After BR, can you please try that?
Prathamesh
Hi @sayan-ghosh
Please try this and if already done and worked, please mark this as helpful.
Prathamesh
