List collector variable issue
Vengadeshgiri
Hello All,
Im facing some issues with list collector variable and getting some error :
"Error MessageInformation could not be downloaded from the server because the transaction was canceled
Transaction time: 15,565ms
Reason: maximum execution time exceeded"
Actually this is on hardware table it may have lakhs of records, and I used reference qualifier that is based on other variable. So Hidden this field on load but still this exeuction error is coming
Does anyone have any idea
Vengadesh
Hi @onkarshivgan
Actually I have two static filter query like
state and substate and one more query based on stockroom
So I hidden that field if stockroom is empty , once value is added lists are populated
 So probably this will work on change of the stockroom
But the issue is only with onload itself
Try this:
use: Reference Qualifier:
if (current.variables.stockroom.nil()) {
    'sys_idISEMPTY';
    'state=1^substate=available^stockroom=' + current.variables.stockroom;
Reload the variable when stockroom changes:
Add Catalog Client Script (onChange):
g_form.clearOptions('your_list_collector_name');
g_form.refreshReference('your_list_collector_name');
Also, I would say for best performance try to use Lookup select box
Seems fine for onload but else part is not working even if stockroom has value
