04-14-2019 11:36 PM
I have a script include which runs every time when the new change request is created. But I couldn't find where it is called from. I have checked in client scripts, business rules, UI action and catalog client scripts.
Can you please let me know the possible ways to call script include.
Thanks in advance.
04-15-2019 09:18 PM
Hi Parimala,
As an admin can you enable debugging and then create new record; it will show what all business rules are being triggered. Also can you check whether that field has calculated value and that script include function is called in from the dictionary level?
04-15-2019 09:18 PM
Hi Parimala,
04-16-2019 12:15 AM
Thanks much for your effort Ankur!
Finally got it resolved. Script include call has been defined inside dictionary entry override in default value field.
04-14-2019 11:41 PM
check first if the Script Include is client callable. By default a Script Include is server side.
Use the following guide, it will help you:
https://codecreative.io/blog/glideajax-troubleshooting-guide/
If I have answered your question, please mark my response as correct so that others with the same question in the future can find it quickly and that it gets removed from the Unanswered list.
Thank you
Cheers
Alberto
04-15-2019 09:31 PM
Script Include: (Ensure the client callable checkbox is checked)
var getStandardFields = Class.create();
getStandardFields.prototype = {
getFields : function() {
var stdChange = this.getParameter('sysparm_std_change');
var standardFields = new GlideRecord('u_standard_changes');
standardFields.addQuery('sys_id', stdChange);
standardFields.query();
if(standardFields.next()) {
return standardFields.u_short_description + '|' + standardFields.u_description;
} return '';
type: 'getStandardFields'
Client script:
unction onChange(control, oldValue, newValue, isLoading, isTemplate) {
if (isLoading || newValue == '') {return;
var classificationType = g_form.getValue('u_change_classification');
if (classificationType == 'Standard') { //MAke server call only if the type is Standard
var ga = new GlideAjax('getStandardFields');//this is the script include
ga.addParam("sysparm_name", "getFields"); //this is the function within the script include
ga.addParam("sysparm_std_change", g_form.getValue('u_standard_change_num'));
ga.getXML(getResponse);
function getResponse(response) {
var values = response.responseXML.documentElement.getAttribute('answer').toString().split('|');
g_form.setValue('short_description', values[0]);
g_form.setValue('description', values[1]);
Also, you must extend abstractajaxprocessor
'The sys_script_include code must extend the AbstractAjaxProcessor class and be client-callable.'
Check below link
Mark Correct if this solves your issue and also mark Helpful if you find my response worthy based on the impact.
